Old 11-16-2010
Angry FAIL
I hate to say this, cause the original build worked so well, but...
As you may, or may not, recall, I sent my SS to sdumper a couple months ago for repair. It was found to have a slow leak that he repaired(?) then retuned and sent the rig back to me.
Upon using it immediately upon it's return, it worked like a champ w/ -40C plus temps at full load.
Then it sat for a month or two.
Hooked it up last night and it took about 20 minutes to register -34C with the CPU dead to the world. Once I booted, the temps nosedived and went positive faster than a ... well, you know. Before I knew it I was positive 30 so I shut it down.
Several more attempts yielded the same results
Was going to use it for some tuning on my bench rig, but now I'm using my Corsair A70 with 5 fans and it's doing a pretty good job (at stock clocks)
Guess I gotta try again and hope the fail sauce turns to win ??
_
Old 11-16-2010
Bummer.
Old 11-16-2010
has the room temps change from the last time you used it ?
mine doesnt like the cold it cant keep the load that good
Old 11-16-2010
there is no magic here, there is still a leak :( sorry to say it
Old 11-16-2010
Yup
Old 11-16-2010
I would advise not to run it anymore as it will take the compressor out soon.
Old 11-16-2010
hey madd the difference isnt that you were using a quad and now you are using a hex right?
Old 11-16-2010
find a local guy who can fix it....not sure if local guy has the gas it needs though
Old 11-16-2010
I'm pretty sure I tested it on the 980 when it first came back from Scott and it help pretty good. Almost has to be the leak issue. Yeah OC, I shut it off as soon as I saw the temp rise like a fuckin rocket ship and won't be turning it on again.
I hate the thought of spending another 100 bucks to send it to Scott again but I don't know anyone in Chicago who does these. I'm checking with someone I know who's husband is into HVAC but haven't heard back yet.... bitch rofl
Thanks guys, I'll just have to use the air to setup the drives, benches, and OSs, then I guess I'm stuck with the juice
Old 11-16-2010
airgas is where my builder got his at
