Overclockaholics Forums » Cooling Performance Section » DICE & LN2 Cooling » What to put on LN2 first ? 1st timer here......
Old 11-07-2010
Talking What to put on LN2 first ? 1st timer here......
Well going to take the dewar tomorrow to get filled and should get cpu pot mon/tuesday
So im stuck on what to do first
Heres what i got.....
980X/R3E
E8500/GA-EP45-UD3P
352/ASUS P5B Deluxe/Modded
Old 11-07-2010
980x r3e nothing better
Old 11-07-2010
im kind of scared if i kill something
Old 11-07-2010
sofos1990's Avatar
The first setup is all about efficiency and many global boints :p
The second one seems ( to me at least ) boring and the last one is all about fun
I would go with the first .
Old 11-07-2010
2nd one....mastery of pot is good exp...
im guessing e8500 will cb @ -120c ....is that e0?
Old 11-07-2010
yes its a E0
Old 11-07-2010
First time is all about going woo hoo
2nd and following times are all about getting the most boints
Take the cheap setup first. Learn it live it love it.
LN2 is hard, if you do it once, and cant do it again you just dont want to bench anymore. Something I know from experience.
Old 11-08-2010
yeah i was thinking of the cheap one first cuz idk what im doing and i wont be to mad if i kill it
but its like $38 to get it filled and not going to do it every week wife wouldnt like that, just droped her off at work she was your just taking me so you can go fill your stupid tank
also we might find out if where having another girl or a boy today
Old 11-08-2010
Just have all boards prepped in case one or two setups don't jive. Always have a backup plan. One doesn't work, torch the pot to heat it up, take it off and stick it in the oven for a few minutes to thaw it out. :S
Old 11-08-2010
are you talking about the pot or mb
im going to use eraser since i have nothing else but you need to put more around the socket area then like i used on the ss right ?
and idk if i wanna wait till the weekend or do it tomorrow, cuz is this something safe i can do inside or be better in the garage ?
