Old 10-28-2010
Default LN2 Pouring Device
I am currently looking at stainless steal coffee pots but want to hear what the rest of you are puring with. Links if you have them. This is what I am thinking of getting.
http://www.google.com/products/catal...=0CIgBEPMCMAU#
Dunno though as the top looks to be to straight for pouring. Other ones have a plastic piece at the top and I dunno how those will hold under extreme temps.
Old 10-28-2010
GeorgeStorm's Avatar
I thought people used thermos?
That kinda thing?
http://www.amazon.com/Nissan-FBB1000...8267068&sr=8-2
Old 10-28-2010
Some do and some don't. Wal-mart has something similar to that but it just looked to be too small. I would constantly being filling it up. I guess those thermals are lined with plastic inside so that answers my question or takes care of my thoughts of plastic not holding up under extreme temps. Thanks George.
Kinda like this too, without the top of course. It has a vacuumed wall:
http://cgi.ebay.com/Vacuum-Pitcher-T...#ht_2303wt_905
Old 10-28-2010
pretty sure this is mine or close to
http://www.walmart.com/ip/Tiger-Amer...l-Jug/13866523
Walmart has good ones, 2L ftw the plastic holds up fine and I just filed down the inside lip on it for straight pouring
Old 10-28-2010
Yah, Walmart has good thermos.
Old 10-28-2010
Yeah I saw that one at Wal-Mart and was worried about the lip. Never thought about filing it down. Good looking out.
Old 10-28-2010
Yeah I'm looking at this:
http://www.houseofsher.com/item.asp?...&txtItem=11111
Old 10-28-2010
georgeS
i think that has a small mouth...hard to fill....
Old 10-28-2010
http://www.ikea.com/us/en/catalog/products/29291800
Old 10-29-2010
I use the ss thermal caraffe off an old coffee maker but found that if I didnt' wrap it in Armaflex it frosted up on the outside too much. I think several brothers swear by the wal mart one so I bookmarked that page for ordering later
