Overclockaholics Forums » Hardware Section » CPUs » Intel » Sandy Bridge....SP1M pawn sauce
Old 10-24-2010
Default Sandy Bridge....SP1M pawn sauce
i was saying this
months ago
alittle after Q1/2011
990x Q1/2011 ...
then i think its sandybridge ..x55 replacement.... this will be superpi1m record beater....i'm thinking the unlocked or the "k" sandybridge will have an unlocked multiplier....
as always 32nm will do 5ghz easy...
look @ hwbot.org topic
http://hwbot.org/article/newsflash/882_
anyways...ddr3 will help us.....new elpidas i hope will clock good..
hopefully i beat dread
Old 10-24-2010
link not working
Old 10-24-2010
http://hwbot.org/forum/showthread.php?p=76750#post76750
this might work
Old 10-25-2010
so is that 5GHz on less then 1v
Old 10-25-2010
Honda, couldn't they just put an external clock gen on the board, route all clocks to the external clock gen. Then let sata, pcie, usb and whatever have a return signal that is stock while allowing you to send a different signal for the bclock? Is that even possible? I'm guessing the external PLL will just send a multiple of the bclock signal sent to it.
Old 10-25-2010
GeorgeStorm's Avatar
No DOM, apparently the voltages aren't read correctly.
Old 10-25-2010
sofos1990's Avatar
Will be like moving from Pentiums to C2Ss . The performance will be WOW !!!
Old 10-25-2010
did you guys see any pricing? if it were to replace the p55...and the i5 chips....this will very fun to play with ....can't wait for 2011
