Originally Posted by rickss69
What you can do Duke is to use painters tape around the perimeter of the cpu and then lightly skin over the top of it. This works well for a chip you do not intend to be swapping out frequently. Otherwise I agree eraser is better around the cpu for usual benching purposes. The tape method is the one I used for the latest small form build which will be using a Boreas TEC for cooling. I will not be swapping chips in this anytime soon and it will take care of any condensation that might arise.
(Was that a magic cape you had on in the video?  )
LOL it was like 6am or earlier i was in my housecoat.
I tried sealing off the cpu with blue tape in that video but it looks like you did it different than i did.
Still like you said, If a person plans on swapping out cpu's then eraser is better in that area. Because once you pull up an edge the rest pulls off with it.
Although i have skinned over skin to repair pulled up edges and that works great.
