Old 03-04-2009
Default DetroitAC pot with IC7 paste
Here's a shot of the Ic7 Diamond frozen pancake:
And with some insulation frozen onto the bottom of the pot which got pulled up:
91% alcohol gets about -68c temps while acetone got a bit higher/lower at -71c:
Old 03-04-2009
3d06= 26188
QX9770 @ 5ghz 400fsb 12.5x
9800gx2 @ 780/1152
790i FTW Analog
CPU-Z = 5337.72mhz
QX9770 @ 5337.72mhz 1.73vcore 464fsb x11.5
9800gx2
790i FTW Analog
Validation http://valid.canardpc.com/show_oc.php?id=463410
HeXus_PI_Fast = 18.78s
QX9770 @ 5202mhz 1.73vcore 433fsb x12 2000mhz Mem
9800gx2
790i Ftw Analog
SuperPI 1M= 8.892s
QX9770 @ 5337mhz 1.792Vcore 464fsb x11.5 1999mhz mem
9800gx2
790i FTW Analog
SuperPI 32M= 10m51.703s
QX9770 @ 5250.8mhz 1.76vCore 437.6 fsb x12 875mhz single channelMem
9800gx2
790i FTW Analog
Wprime 1024m = 236.203
QX9770 @ 5251mhz 1.76vCore 437.6 x12
9800gx2
790i FTW analog
Wprime 32m = 7.363s
QX9770 @ 5337.4mhz 1.792Vcore 464fsb x11.5
9800gx2
790i FTW analog
