Overclockaholics Forums » Cooling Performance Section » Water Cooling » water kills hardware? what about w/ peltier?
Old 10-15-2010
Exclamation water kills hardware? what about w/ peltier?
kk.. now i just dug out my Swiftech pump MCP655, Swiftech reservoir MCRES-Micro, Swiftech MCR320 AND MCR120 radiator... as i was looking around i found there was this little white thing in the corner of the box i picked it up, and turned out if was one of my old peltier i have used in the past , so i hooked it all up and all..
btw how hard dose the MCP655 sock?
cuz before i hooked all up in a closed up system it doesn't even sock at all...
i thought i was broken i was freaking out but as soon as i hooked it up in a closed setup everything starting to work...... WTF? or is it just me?
and now here is what i got...
http://img836.imageshack.us/gal.php?g=p1000217z.jpg
Old 10-15-2010
that pump is high flow...mid pressure....you need to bleed the loop first.
just becareful with the 12v.
Old 10-15-2010
yup!
now i just gotta install all that in the rig then done =)
btw it hits sub zero with out the chip installed
Old 10-15-2010
Here's a project for you kiki...looks like a lot of fun to be had here... http://www.overclockers.com/nuclear-...water-cooling/
Old 10-17-2010
Whats the rating on your pelt?
Old 10-18-2010
that's still a little bit too much for me
i was gonna use my old car rad for it but my dad accidentally put it in the trash
what an ass! lol
i think it's a 68W pelt.. or 60 something
so...
when i was playing around and just left it on and just walked off =)
and then when i came around washing my hand i dropped a few drops of water on the pad accidentally, so i was gonna wipe it off...
and the water was not going away when i was wiping it...
THE DAMN THING GOT ICED!
Old 10-19-2010
Water kills
Always insulate the board around the socket and make sure your connections are tight.... or else
Insulate around the pelt too as condensation will form otherwise. Don't think 68 is gonna do you a lot of good once your slamming the petal to the metal, but, let us know
Old 10-19-2010
WATER BONG!%!@
Old 10-19-2010
WATER BONG!%!@
Yep - I'm going to do it just for the fun of it.
Old 10-19-2010
Water kills
i insulated the board just like i was running it with ln2 or dice
everything was good but not great...
i just had everything hooked up and just had a few test run and all..
it was not wroth the trouble at least not the low wattage petal
i may get like a 180 or 250 just for the hell of it
go big or go home right?
same here..
i was really that big of a water fan
that's just me tho
i ran water for a little
it's just one of those things not really for me..
on the other end...
DICE is a hell lot more fun then what i though ..
and LN2 has always been funner then a retard trying to hump a door nob
i can do it all day long and not get sick of it
