Overclockaholics Forums » Hardware Section » Motherboards » Intel » REX gurus GTF in here!!
Old 09-24-2010
Smile REX gurus GTF in here!!
I need some help hitting 600+ fsb on the rex ...
I have 2 e8600 and both top out at exactly the same 5.75ghz because I cant get the bus speed higher.
Any key voltages or settings that I should know about?
Is it absolutely necessary to freeze the nb?
Any help is appreciated
Old 09-24-2010
Trying to remember but have you jacked with the gtlv lanes? I know tweaking those helped me. I never took it over 6 ghz so dunno about freezing the nb though I have seen many do this. Can you post up some of the settings you are using?
Old 09-24-2010
2chesapeakes's Avatar
IIRC my board hits 600FSB with most settings to auto multi set to 7 play with NB volts and Vcore and possibly VTT. Also I found with 2 sticks of 2GB ram my board would max about the same as yours. 1 stick 1GB ram and 600 - 615FSB is not much a problem.
Old 09-24-2010
Oh lord, back into the world of 775 GTL lol!! I will get some settings in here once I get it up and running later. Just trying to better prepare as last time on 775 was a complete fail.
Ill try one stick, was using 2x1gb thanks.
Old 09-24-2010
I'm fixing to be back down that street too next week when the Black Opps arrives. Kinda gotten spoiled on overclocking with the core iX platforms.
I can only imagine if you are wanting to get upwards of 6.5 GHZ that will require alot of NB volts and might require a pot. Then again I might just be full of it as I have never been that high. Good luck.
Old 09-24-2010
I HATE not having ROG connect or an evbot .... clocking in windows ftl!
I didnt get a working lcd poster with this board either.
Old 09-24-2010
$17 shipped FTW!!!!
http://cgi.ebay.com/NEW-ASUS-Externa...#ht_500wt_1154
Old 09-24-2010
hey dentene ice
http://www.xtremesystems.org/forums/...d.php?t=196683
time to read a novel!
Old 09-24-2010
Sweet Nip thanks
What about mem strap, what is best for high fsb ??
Ahh superSplave to the rescue!!
/me gets his reading glasses ...
Old 09-24-2010
Gunslinger's Avatar
Overclockaholic
600 on aircooling should be pretty easy with everything on auto, I wouldn't freeze the NB, but instead use a little watercooling.
