Old 04-12-2009
Default Use Protection!
When using a chiller or any other sub-ambient cooling, always always, use condensation protection as condensation can creep up on you at any time when below ambient.
This is why you must take the time to guard against condensation:
A little closer look:
Old 06-28-2009
Kal, the pics are dead :(
I use about 12 large maleable erasers to cover the mobo, then about 1/2 roll of the thick insulated tape. I eraser all the mounting screws, then wrap everything so the entire space between the ram, mofests, and heat sink look like a nuclear reactor lol PITA to tear down, but never any problems with condensation Should be a pic in my pic post
Old 06-28-2009
limpkorn's Avatar
limpkorn limpkorn is offline
Junior Addict
limpkorn is just getting started
I want to see those pics. Can you fix the links? I'm contemplating Phase and I want to start getting informed. Thanks supes!
Thermaltake Spedo Advance
EVGA X58 Classified NF200 Version
Core i7 920 4.4Ghz w/ Koolance CPU-350 Water Block
Mushkin Redline 3X2GB 2000mhz 8-8-7-24-T1 Kit
SoundBlaster X-Fi Titanium Fatal1ty Professional
WD 300GB 10K RPM VelociRaptor X2 in RAID 0
Seagate Barracuda 1TB HD
3XEVGA GTX 280 in SLI TRI-SLI w/Koolance Vid-428 Water Blocks
Ultra X3 1000W Power Supply
FPS X5 450Watt GPU PSU
G11 Gaming Keyboard G5 Gaming Mouse
Samsung Syncmaster 2493HM Monitor
Old 06-28-2009
fixeded
Old 06-28-2009
ouch how did that smell
Old 06-28-2009
I had sprayed on some electric tape spray around the cpu socket and used vasoline in the cpu socket itself so I came away a winner with the drip drips.
Old 06-28-2009
Classic shots supes!
