Old 09-15-2010
Default REX LN2 NB?
Put a pot on top where the waterblock goes?
Or cut up the chipset heatsink apparatus to isolate the NB?
Old 09-15-2010
lol i am just flat out putting LN2 and DIce on the damn NB heatsink lol
then block it out
lmao
i'll post some pix soon =)
Old 09-15-2010
Isolation is probably best. Heatpipes are not designed to work at -190C.
But mainly I think you dont want to uber freeze the VRMs...
Old 09-15-2010
Condensation on the VRMs can't be good.
Old 09-15-2010
For resale reasons, you might want to take the old heatsink off whole... and take sinks off a a dead mobo or something instead as well...
Old 09-15-2010
yeah i just place more orders on the Design Kneaded Rubber Art Eraser lmao
i just ordered 12 should i get more?
Old 09-15-2010
12 is plenty.. If you ordered the jumbos... I ordered a box of them after getting 5 or 6 locally. Still have not opened the 12
If you use vaseline too you will go through it quicker though (throw out eraser that gets PJ on it)
Old 09-15-2010
I've done it both ways on various mobos.
Really it depends on how cold the NB can tolerate.
If the REX NB can tolerate less than -120 to -150, then I'll isolate it. But if it bugs at -30 to -40 anyway, it would be much better to leave the heatsink intact.
Old 09-15-2010
karmakazi's Avatar
I had good results with pretty high temps, ~-20 if i recall. I just put crushed dry ice in the nb pot and no acetone
Old 09-15-2010
http://img155.imageshack.us/gal.php?g=img0056am.jpg
take a look at here ^_,^
that's what i did
