Overclockaholics Forums » Cooling Performance Section » DICE & LN2 Cooling » Will 30 liters of LN2 be enough?
Old 09-08-2010
ny_driver's Avatar
Default Will 30 liters of LN2 be enough?
I have a welding supply store only 15 miles away so getting more will be easy. The guy said $45 for the 30 liters and $75 a year rental or $8.xx a month. $18 for delivery, but I'll just go get it.
How quickly can a freak like me use up 30 liters of LN2?
Now I must either make a "POT", or maybe buy one. My uncle can make anything out of metal.
How much is a good "POT"?
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 09-08-2010
30 LN2 is a good 8-12 hours on a CPU pot I think depending on chip used. Hotter the chip the less time it will last.
30L lasted me 2 sessions 3 days apart. (2nd was short though... only about 2 hours)
I am a noob though...
Old 09-08-2010
ny_driver's Avatar
Wow that's pretty shitty.
The 180 liter is $1.50 a day rental and it weighs 700 pounds, but would look nice sitting in the garage. The 180 would probably last me a month.
That would be ~$200 a month if I can make it last.
180 really wouldn't be too much LN2 at all.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 09-08-2010
Gunslinger's Avatar
Overclockaholic
A good pot will run you about $200
Used pots can be had for nearly half that. There's a good used F1 EE at XS for $125 right now
32L only lasted 4 hours on Gulftown my first time.
Old 09-08-2010
You are on AMD so should not have to torch your pot and waste a lot of LN2. Also dont let your transfer cup stay empty too long, the more it warms up the more you lose to evaporation when you refill it.
I do imagine a 6GHz Thuban would be pushing towards the 6 hour time frame though LOL
Once I have a steady stream of HW I am going to rent a 160L.... costs me $150 a month I think...? (came to 80 cents a liter plus $45 rental and $18 hazmat/delivery charge)
My 30L cost me $70 bucks to go get filled :(
Old 09-08-2010
ny_driver's Avatar
Thanks for the info Gunslinger.
He told me .92 per liter for 180 liters...all other charges the same. Sounds like I could really go through some LN2. I need to get the bulk tank the welding supply guy has......lol
EDIT: or marry his daughter.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 09-08-2010
Less than $29.00 here to fill my 32l....I would shop around.
Old 09-08-2010
ny_driver's Avatar
I'm sure I could get it cheaper if I wanted to drive ~45 miles one way to get it. Have to look around some and weigh the options.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 09-08-2010
Might be a good idea.
When you called was that OTC pricing or with an account?
Old 09-08-2010
ny_driver's Avatar
I don't have an account there yet.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
