Old 09-03-2010
ny_driver's Avatar
Default Thermometers?
Where can I buy a temperature probe that I can slip in between the edge of the cpu and waterblock?
Thanks
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 09-03-2010
Cheap Digital Thermometer w 2 K-type Temperature Probe Sens
Old 09-03-2010
Extech easyview 10 is what I have
can run two probes off it....
Amazon is where I got mine
http://www.amazon.com/Extech-EA10-Ea.../dp/B00023RXEG
it is orange when you get it ???
Old 09-03-2010
Thats what I have. It is not the greatest but it gets the job done. You can monitor either probe temp or monitor the differnce between them IIRC. (have not used mine in a few months)
Old 09-03-2010
been checking out the tenma...
http://www.mcmelectronics.com/produc...-7712-/72-7712
Old 09-03-2010
ny_driver's Avatar
Probably will get one of the DM6802b from Ebay. I'm not going below -50 Celsius right away.
Thanks for the help mates.
EDIT: I bought this.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 09-03-2010
The probe listed on ebay does read below -50C . -50 is the rating of the probe not the thermometer. Any K type should say down to -50C... its just not as accurate after that point. Mine registered -74C on DICE, and I do not recall what it read running LN2...
EDIT: at least as low as -135C
Old 09-04-2010
Accurate temps are not that important. As long as the probe is consistant it will do perfect for what we do. We aren't keeping meat or semen, we're chilling hardware.... and the temps between systems are going to be relative at best with any cooling anyway.
... so pay no attention to how "accurate" the probe/thermo is. The purpose of using them anyway is to determine a cb/cbb threshold and monitor so the load handling of the cooling doesn't break down unchecked.
Old 09-04-2010
ny_driver's Avatar
So that one I got for $12.99 from Hong Kong should do fine.
What is cb/cbb?
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 09-04-2010
cb = cold bug
cbb= cold boot bug
cb is when you are already running and the comp bugs out or locks at a certain temp <0
cbb is the point at which the pc will not post/boot below or at a certain temp.
