Old 08-28-2010
Default AB Safety checkboxes
When using Afterbuner, are you guys checking off all three boxes?
Old 08-28-2010
i did on the 5870
Old 08-28-2010
Everything but force constant voltage.
Old 08-28-2010
i did on the 5870
Why?
Old 08-28-2010
you should only need to force constant voltage if you crashing after the benchmark is finished because of idle swings... it should keep temps up on subzero If it's not crashing after the bench, you don't need it.
...well, that's the theory.
Old 08-28-2010
force constant voltage.....helps with screenshots..
