Ok boys, you should consider yourselves lucky to be able to try my customized benchmarking-oriented Windows
( ok, I might be overreacting and exaggerating
I don't get to talk nice about myself often
Ok! ok! I'll stop mumbling
I haven't integrated any CD Keys, so yes, you can legally download these operating systems and try them for free for 30 days without a key or forever just by using your genuine CD Key.
They're in ISO format archived in split RAR files.
Just download the archives and extract the ISO and burn it with a cd/dvd burning application ( Nero, etc ).
The links are interchangeable.
Here we go:
Windows Vista Ultimate x86 Xtreme
Filelist @ BenchZone:
Code:
http://www.benchzone.com/Downloads/Temp/WVx86X/
"Link-list" @ RS:
Code:
http://rapidshare.com/users/EHJNCL
The password for the archive is:
Windows 7 Ultimate x64 Xtreme
Code:
http://www.benchzone.com/Downloads/Temp/W7x64X/
"Link-list" @ RS:
Code:
http://rapidshare.com/users/A128Z5
**NOTE**
In the end of the installation you might get an error window, if you get the error just do the following:
DO NOT CLICK OK @ THE ERROR WINDOW/DIALOGUE
1) Press Shift + F10 to open a command prompt window
2) Type CD C:\Windows\System32\OOBE ( and press enter :p: )
3) Type msoobe ( and press enter...
4) Fill up the info ( username, password if you want, timezone, etc ) and click Finish
5) Now in the CMD window again type Audit and hit enter
6) Click OK on both error/warning windows, the system will restart and finish the installation.
You might get an automatic restart in the first boot.
Have fun!
Windows 7 Ultimate x86 Xtreme
Code:
http://www.benchzone.com/Downloads/Temp/W7x86X/
"Link-list" @ RS:
Code:
http://rapidshare.com/users/YXGRYT
**NOTE**
Have fun!
Windows 2003 Server E.E. x86 Xtreme
Code:
http://www.benchzone.com/Downloads/Temp/W2k3Sx86X/
"Link-list" @ RS:
Code:
http://rapidshare.com/users/Y4VL8J
**NOTES**
I forgot to integrate an executable called nhelper.exe, so to get past that annoying message @ startup:
Grab it and copy it to C:\Windows, C:\Windows\System32 & C:\Windows\System
RapidShare
Code:
http://rapidshare.com/files/358593107/nhelper.exe
BenchZone
Code:
http://www.benchzone.com/Downloads/Temp/W2k3Sx86X/nhelper.exe
Windows XP Professional SP3 x86 Xtreme 2 ( 3D Mark Series System Info Error Fixed )
Code:
http://www.benchzone.com/Downloads/Temp/WXPx68X2/
"Link-List" @ RS:
Code:
http://rapidshare.com/users/DCL8AT
Windows XP Professional SP3 x86 Xtreme ( SuperPi, PiFast, wPrime )
File @ BenchZone:
Code:
http://www.benchzone.com/Downloads/Temp/3DxpMark.rar
File @ RS:
Code:
http://rapidshare.com/files/203741231/3DxpMark.rar
Enjoy
