Old 04-03-2009
2chesapeakes's Avatar
Default My First Attempt at LN2
I will say if I intend on doing more LN2 runs I will need a better pot. The aluminum pot does not hold temps and requires alot of ln2 for a 3d06 run.
I was able to borrow a 30l dewar and most of that was used just reworking my saved OC profiles. I was able to bench for 7 hours on LN2. The CPU would cold bug when the pot reached approximately -100C my quess is this was around 070C CPU temp.
Well anyway here are the results of the session. I have a new personal best 3d06 dual card and single card.
Old 04-03-2009
Very nice buddy. Could you post them submissions up in the hwbot forum too? I see it did net you some more cpu mhz for 06 though
Old 04-03-2009
Nice man. I need to look into gettin a dewar myself in the near future. Prolly need to get a 775 cpu and mobo for it though as it would prolly be pointless on my 920.
Old 04-03-2009
I thought cold bug was less of an issue with the DO stepping??
Old 04-04-2009
Jeff, I have a spare copper pot with a good amount of mass that should perform well with LN2. Lemme know and I'll ship it out to yah lickidy splits. I've run DICE on it and it did well for me. Looks to me it'd perform well with LN2.
Old 07-13-2009
youngpro youngpro is offline
youngpro is just getting started
nice runs mate, a good start.. you will definatly see improvements if you move to copper from aluminum... especially in ability to control that temp and hold load
