Old 06-16-2010
skarface's Avatar
skarface skarface is offline
skarface is just getting started
Default Skar's updated i7 rig
Well ive done a little work over the past several months!
Here is the list:
1. cpu block koolance 360
2. better cable management before i had none
3. All fans on rads are scyth gentle typhoons 1850rpm 28db very exspensive for fans
4. 2 gtx 480s
5. 2 koolance water blocks for the 480s
6. moved a pump so that its not as visable
Here is my crysis theme too!
raid 0 seagte baracuda 320s
seagate baracuda 500 gig
x58-ud5
sli gtx295
i7 920 do step5
1200 xclio
mushkin redline 6 gigs (pc 16000)
corsair dominator fan
2 koolance reservoir 1 magicool reservoir
2 cpx pro pumps
koolance 330 cpu block and koolance video blocks
stealth ice gt triple rad
black ice steal gtx extreme 240
heatware
Old 06-16-2010
Oooo! That looks like warp speed!
Old 06-16-2010
skarface's Avatar
Thanks its been a working progress man! I do alot of lans and really want a bigger case but i dont think i can break down and do it! This mid tower had been carried all over my town every other weekend and its heavy and hard enough much less a full tower! But the extra room would be sooo nice!
x58-ud5
sli gtx295
i7 920 do step5
1200 xclio
2 cpx pro pumps
heatware
Old 06-16-2010
enjoy murdering any game for the next 200 years
I love the res, good work
Old 06-16-2010
skarface's Avatar
Thanks alot man i like the res too but i really want to use this one.
http://www.frozencpu.com/products/10...l=g30c97#blank
but it doesnt hold as much fluid as the one i currently have so it more of eyecandy than performance. Id rather have the extra fluid for dwell time.
x58-ud5
sli gtx295
i7 920 do step5
1200 xclio
2 cpx pro pumps
heatware
Old 06-16-2010
Sick work man! Enjoy it.
Old 06-16-2010
RomDominance's Avatar
Nice lookin rig there Skar.
Old 06-16-2010
Wow man that is a major improvement in cable management! Looks sick now! Man I used to bug the shit out of you for that little tiny mid-tower. I wouldn't go to a full tower man. You move it too much. If anything just get you a larger mid-tower yet still small enough to move around. I'm a fan on Lian Li myself, but I got outa the case scene.
Old 06-16-2010
Tight looking work, nice job man
Old 06-25-2010
skarface's Avatar
Well got a bug to break the 30s! I know ppu isnt dis but the higher number makes me feel good lol!
x58-ud5
sli gtx295
i7 920 do step5
1200 xclio
2 cpx pro pumps
heatware
