Old 06-08-2010
Default UEI DT3xx Users
...low battery....it wouldn't turn on.
...i replaced the battery..
...full reset...
...set my settings...
fuck t1: 460C
fukc t2: ---
notes:
1. battery blinking before i replaced battery.
2. lost calibration when battery is totally drained
3. t2 is now dead
4. will post rma results...
just sharing ....
Old 06-08-2010
Mine won't read two probes at once now, I dunno wtf is up.
Old 06-08-2010
just now?
Old 06-08-2010
My old battered DT200 has had the same issue the last few months.
1 probe OK
2 probes I get wildly weird readings - super high temps on one and super low on the other.
It fixed itself for one battery change, but the problem is back for the last few batt changes.
Funny thing is I started having the exact same problem with an el cheapo from Hong Kong. Been using separate probes for things.
Old 06-08-2010
Yea mine is a POS too. I lost calibratioon a while ago. Threw it on the shelf and bought a Extech. UEi read is off by aboout 40 degrees.
Old 06-09-2010
What batteries are you guys using? Have any of you tried cheap branded batteries?
Old 06-09-2010
i think we ought to replace the batteries when the battery light is blinking...mine died completely so it prolly lost its charge...
i'll call uei today
Old 06-09-2010
sofos1990's Avatar
I had a DT302 . Batteries last looonger than DT200, that's for sure
It is as fast as Fluke series 5 . No difference .
Never had a problem with it , I bought it brand new though .
That's my experience on it
Old 06-09-2010
what i'm trying to message out is ...change the battery when its blinking..but for now..i'll do rma on it.
Old 06-09-2010
Jor-El's Avatar
Jor-El Jor-El is offline
Funny my UEI did the same thing after my battery was dying. I changed for a new 9v one but the temp sensors are not accurate anymore, I retired it and got another Fluke...
//RETIRED OVERCLOCKER//
