Overclockaholics Forums » Cooling Performance Section » DICE & LN2 Cooling » Drying / Reviving HW Coz of LN2 / Dice Possible Condensate .. Fermilicious is Back
Old 06-07-2010
Default Drying / Reviving HW Coz of LN2 / Dice Possible Condensate .. Fermilicious is Back
480gtx died yesterday
error code: 2e - output device not initialized.
visible water everywhere.........this is done to dry up boards fast
Fix / Recommendation:
1. inspect board for cap burst...broken resistor..if found prolly won't save it. sides of the gpu core...also water could have gone inside...this might take more patience/days
2. ipa and cotton buds.. clean off whateer residue you see..they might smell later.
3. convection oven @ 100c don't close the oven...this is just to keep the solders not melting even though they melt at 150+ c
4. infrared thermometer: monitor temps. some convection ovens start @ 200C which is pretty close to melting solder.29$ from home depot
5. patience: priceless
Notes:
1. some have used dishwashers....its the last resort really.
2. alternative: incubators...they come with babies too.
3. alternative: flood lights...200w versions are ok..but the heat is concentrated just on top..it works too.
4. i used a glassware to put my video card into so it won't short anything out. the grill is partly metal..i didn't test for conductivity..and its lil rusty anyways lmao.
fixed my 480gtx..fermilicious is back
Old 06-07-2010
I always set my my card pot down, at a slight angle so everything drips down the edge without the PCI-E fingers Find a sunny window and the next day you are good to go.
also compressed air works great blasting water off.
