Overclockaholics Forums » Hardware Section » RAM » Decent Kit For P55-GD80
Old 05-29-2010
Cecil Cecil is offline
Cecil is just getting started
Default Decent Kit For P55-GD80
Got a cheap GD80, and will probably grab an i5-650 from MC. Just need a simple 2x1Gb benching kit. These good?
http://www.newegg.com/Product/Produc...82E16820231349
New Sig To Come
Old 05-29-2010
Ya know I think Nickshih and Hiwa have used "that" kit. The trick is that theirs have hyper IC's by the timings they got. I doubt any retail kit is anything other than PSC or BBSE. Still should be plenty fast for some fun though.
Old 05-29-2010
Think its worth it to get those for water benching, instead of the 2x2 Gskill Ecos I have?
New Sig To Come
Old 05-29-2010
Well 2GB density seems to be the sweetspot for DDR3 like 1GB was for DDR2. Still might be worth a try. I don't see them being hard to sell quick if they don't work out.
Old 07-17-2010
I am running Gskill Tridents with my P55 GD-65 setup @ 7-7-7-22 around 1400-1600mhz getting them higher proves to take a lot of voltage tho...
