Old 03-29-2009
Jeffro64's Avatar
Jeffro64 Jeffro64 is offline
Default How depressing....
I made some runs on Vantage with PhysX turned off after Supes reminded me that it can't be used for posting on the bot. Sure made a huge difference in my scores.... I feel like i'm on a PIII again.
Main Rig
Case - Cooler Master Cosmos S
PSU - Corsair HX1000 1000W
DVD - LG 22X GH22LS30
OS - Vista Ultimate 64bit
Old 03-29-2009
Man oh man. Yep you have to have it off for HWBot submissions. About the only place I can think of that uses it and makes a big deal out of it is over at EVGA. They live by it. It will be alright though.
Old 03-29-2009
Jeffro64's Avatar
We'll see what happens if they release a good bios for this board that don't have all the holes and other problems. That could be a couple months as slow as EVGA is.
Main Rig
Old 04-01-2009
Egor
Guest
Posts: n/a
I'm sure if you were registered over at hwbot, you'd get at least a few points for those runs. Those Tipi smokers at Evga dont' know any better.
I hear the digital pwm's get hot as hell, what are you cooling them with?
Old 04-01-2009
Jeffro64's Avatar
Yes it does get quite hot if I push it any farther than I am right now. Just using the domino in my sig and the rest is air.
Main Rig
