I'm new on here but have been around the OC community for a few years now.
New build that should get interesting. I hope you enjoy.
Here's the goods.
Case:
Corsair 800d (Yes another one.)
Cooling:
2x TFC 360's
1x TFC 240
2x D5's
1x EK Dual D5 top with 140mm Res
1x EK Supreme HF
2x Koolance 5870 GPU Blocks
1x Koolance mobo block
Lots of compression fittings
10x Delta 3300rpm fans
Some UN goodness. Thanks Dave!:up:
Hardware:
I7 930
EVGA Classiffied 760
6GB Corsair Dominators
2x XFX 5870's
X-fi Titanium sound card
Dual layer DVD burner
WD 640Gb Black HDD
1200 watt Topower Powertrain PSU
All of the cooling will be internal including the 3 rads.
Started taking the case down.
I got the HDD bays out.
I still have some more to do. The mid plate has to come out to be replaced.
But here are the rads that are going in. I want to put 3 x 480 Rads in but I have to get my hands on some first.
Also, I have a sweet ass bracket for the dual D5 pumps. I had this bracket custom made for this build. It's in the raw I have to get it plated.
A big thanks to Dave @ UN Designs. He did a hell of a job.:up:
This will give you a good idea of where this is going.
The case is gutted for the most part.
I did some measuring and mock ups so I can start fabricating and cutting.
The PSU is going to move up to the front. I used a fried PSU I had laying around for the mock up.
The bottom will be dedicated to rad space. I decided I would make the bottom flexible to fit either 240, 360 or 480 rads. I will also make a new midplate and mounting brackets for the rads as well.
Stay tuned.:up:
Still trying to obtain some more parts for this build. I need to get my hands on 3 480 rads and some other things.
