Old 05-11-2010
crio's Avatar
crio crio is offline
Default CC-Pot Rev1.0
Hello everyone.
After trying many many pots i think it was about time to make my own. The designs where made, the Copper was bought, the lathe was found and finaly it is my great pleasure to show you the
CC-Pot Rev1.0
The extrerior is not 100% as it has to be lapped and cleaned but you get the picture how it will look......
The outer look
Hole for the thermocouple
The inside....
Wearing its costume...
A huge thanks to JC_Denton for the pics and to Gorillakos for the Tips....
Crio OC
Old 05-11-2010
Kool man, how much does it weigh?
Old 05-11-2010
i tried round and square pots....
round is a hit and miss with mounting...
square pots are easier to mount...
with ln2...
starting @ -100c with a heatload(wprime1024) of i7-980x(only an example)(say 1.6vcore again only an example) how fast does the temperature drop to -70c? this is without addition of liquid nitrogen... this is a question for how much the base can hold temps. i suggest a timer....
this is not to judge your idea.....i'm just curious.
thanks for posting ...what is the diameter? 80? 70?
Old 05-12-2010
with ln2...
Different people have different pouring styles. Patch likes a pot that warms/cools quick with a thin base. He likes to rapid pour.
Nice looking pot Crio.
Old 05-12-2010
Old 05-12-2010
Nice looking design .... how deep are each of the steps at the bottom ? hard to tell from pics .... Thta would be adjustable for future pots to tune them in for your prefered temp holding preference.
wet sanded down and buffed on the outside and it would be a very sexxy peice of hardware ....
What type of mounting backet you using ?
Old 05-12-2010
obviously the question was for crio....
got an answer for my question above? or you already know its like patch's pot?
No shit, I know who the question was for. That's strike two Honda. I'm reluctant to let you make it to three. You just come into every thread acting like you are a know it all engineer and have confrontational post. You post could easily be taken as putting his design down. I suggest you think very hard about your next response.
Old 05-12-2010
crio's Avatar
The diameter is 7cm and its 12cm long
The design was a mix of three things.Old MickeyMouse design (the steps),Gorillopot and my ideas.I will soon test it with a hexa core CPU and let you know.The holddowns will be ready tommorow.They will be made from acetal.
Crio OC
Old 05-12-2010
Are you selling these in the future or is this just a personal project?
Old 05-12-2010
crio's Avatar
If CC-Pot performs as i want it to i will sell for sure.
Crio OC
