Overclockaholics Forums » Hardware Section » RAM » ddr3(x58/p55) on p45/x48(ddr3)
Old 05-11-2010
Default ddr3(x58/p55) on p45/x48(ddr3)
well its been mentioned by Gunslinger and i forget who...
thanks for mentioning using it....
this very well made me decide to hop on the 775 platform again ..
i'll post some results once the mobo arrives, hopefully my cpu is good..and the nb good...and the bios good...
Old 05-11-2010
Good luck with that mate! Like I said in the other thread it should be no problem with the X58 ram. I ran out of time for today benching but tomorrow is E8700 + EP45T-USB3P and SuperTalent CAS8 2200Mhz time! When the combo performs it will be o1 and 03 time with the modded GTX470.
Old 05-11-2010
hahahha almost the same setup...
i was looking at the gigabyte p45 ddr3 board....same rams..but i'll use my kingstons first just to be sure....
oh yeah notes of mine says 1.6v on the nb of p45.....and a pot or use a thermalright tower on the nb
lemme know what happens
Old 05-11-2010
I'm still deciding on the NB cooling. I mean the P45 runs so cool any way and I pretested the FSB already. I can hit 600FSB stable and 630 CPUZ on stock volts. Seems like there is no need to go all out on the NB. I might throw water on it just to see if this makes any difference.
Old 05-11-2010
600? WOOOW
thats 6300mhz with 10.5x
can i see memory subtiming? vdimm?
woooo great stuff
Old 05-11-2010
600? WOOOW
woooo great stuff
Yeah I tested on a 7 multi so we so how she runs when I slam 2V in there. Also CB is my FEAR since I'm on cascade so she needs to be good for at least -125C
Old 05-11-2010
The only thing the cooler NB will do on the P45 is probably allow for tighter PL. X48 does run a little warm though.
Old 05-11-2010
Yeah I remember the old good days of the BLackOps and the NB on LN2. It made sens to use it on X48.
Old 05-11-2010
That's one board I wish I had got to play with. I still wonder if that board could have competed with the REX if it had proper bios support??
Old 05-11-2010
the northbridge is around 50w over 1.6v...slapping a pot is easy...no need to go -90c just -40c....is good..and you don't need to over insulate...
once its subzero you can pretty much push the nb...
ln2 on p45's northbridge
http://hwbot.org/community/submissio...eme_750.92_mhz
http://hwbot.org/community/submissio...s_plus_735_mhz
http://hwbot.org/community/submissio..._i45_725.5_mhz
http://hwbot.org/community/submissio...eme_705.58_mhz
