Overclockaholics Forums » Hardware Section » GPUs » ATI » Can't run Vantage || com surrogate error
Old 05-04-2010
Jor-El's Avatar
Jor-El Jor-El is offline
Question Can't run Vantage || com surrogate error
Googled this error but nothing good came out.
W7 x86 10.3cat:
Help!
//RETIRED OVERCLOCKER//
Old 05-04-2010
That used to happen to me in Vista and XP, but never in Win7. May be a very painful remedy, but give Rom a call - I don't remember the fix but remember it sucked
Hopefully I'm wrong Good luck Bro
Old 05-04-2010
Uninstall and reinstalled? I wanna say this happened to me a while back but can't be for sure. I do know that I had an error like this happening though.
Old 05-04-2010
Jor-El's Avatar
Ya this is bad.. I'm trying W7x64 now but man these things only happens on 3D!!!
Old 05-04-2010
i found this solution on another forum
Actually you know what worked!? I DID NOT have AHCI mode on...I was in IDE in the Bios. I had to edit the registry to enable AHCI in Win 7 then change to AHCI mode in the BIOS and restart. (after installing latest drivers for such)
also maybe try this
http://www.howtogeek.com/howto/windo...rror-in-vista/
Old 05-04-2010
Win64 you should have no probs, but I"m thinking the fix is worse than uninstall/reinstall Vantage ...
Old 05-04-2010
You got any services disabled/stripped?
Old 05-04-2010
Let em guess you just unistalled some ATI Drivers ?
that rat poision does it to me everytime
reinstall is what I do, and seems to work
Old 05-04-2010
delete the cache folder?
Old 05-04-2010
Tried installing 06? That has worked for me before.
