Old 03-30-2010
Question almost done with it! [please read #18]
it's been about 3 weeks from last time i worked on my system at all...
just installed my new water tank, i just got the Thermal Take Aqua M3 1U Tank off ebay lol
pic 1-14 are my system up to now..
pic 1 and 2 are the main part of the watercooler i am using the everything from that set
pic 3 is the new toy i just got it's a tank made by ThermalTake looks kinda cool and i can put a HELL LOT MORE water in it now lol
pic 4 is the thermal compound the only Korean thing i will ever put my hands on well... Zalman stuff...
pic 5 is my Q6600 G0 lapped nicely
pic 6 is the extra liquid that came out of the stock Coolermaster system..
can i or can i not mix coolermaster water and Thermaltake water in one system?
pic 7 is the water i put in the system... seems like it's just stander drinking water, there is nothing in it, is that good for the system or not?
pic 8 is just a closer look of the tank
pic 9 the water flower
pic 10 is the in and out put connection of the tank, very bentable
pic 11 and 12 is this a good idea? cuz the the thing will not fit around it
pic 13 you see how on the black tub there is a thing around the end, but on the green one there is not one on it [will not fit]
pic 14 that's just a extra water block that came with the system and just sitting by my 80mm fan, it keeps IT cool not really sure if that helps or not, it seems like it did
what do you guys think?
i really think i need another bigger water readitor, and a hell alot stronger pump in my system
Old 03-30-2010
Question is....... Does it suit your purposes?
Old 03-30-2010
personally i don't think it did much, with out a better water block
and also a RADIATOR
but working on this thing just makes me happier
Old 03-30-2010
watercooling is fun...until you find out..LN2 is so much more fun
Old 03-30-2010
and also a RADIATOR
Kiki, if you can find an old a/c unit that someone is throwing away or doesnt want anymore, you can convert it into your water=cooling plans and supercharge the cooling portion of your plans.
A quality pump would be needed to move the coolant around at sub-zero temps, insulation prep on the mobo but you'lre gonna get much better results.
Old 03-30-2010
and also a RADIATOR
If your having fun than it's worth it.
Old 03-30-2010
+1 Homebrew chillers rule. You probably need clamps on the green tubes.
Old 03-31-2010
Talking
old ac got it!
but how can a water cooling system with fan and air become sub zero temp? i have always wanna ask that
Old 03-31-2010
i am happy when i am overclocking...
until i can't improve and keeps trying and trying for 8hrs and staying at the same place it's just like WTF DUDE!
but yeah i love been here i love working on my computer and car or anything that's gonna keep me working lol
loved the shit outta my x but now it's only my x </3
Old 03-31-2010
old ac got it!
To go sub-zero takes a good bit of modding.
You pretty much need to dismantle the old a/c unit in question and put the evaporator in a cooler, and put the rad (or rads) in the cooler with it, and then fill with distilled water/antifreeze or whatever concoction Kal came up with worked well too..
Porting the a/c air directly through the rads or h/s helps, but I only got to zero with the machine off.
