Old 03-28-2010
Default extreme cooling cards
Borrowing Juans pot for a bit... and got about 6-8 cards to pound through that I want to vmod...
I expect I need ramsinks... or do I ? At least for VRMs? I dunno...
couple 7600gts.
couple 7800gts
7900gt, 9500gt,
and maybe a 7900GS... (not two.. lost the other one)
Old 03-29-2010
vrms prolly but ramsinks dont' think so. Dice or Ln2?
Old 03-29-2010
The ram is right next to the pot and usually is cold as hell, especially on ln2. I put them on sometimes, but have never had a problem if i didnt.
Old 03-29-2010
http://www.frozencpu.com/products/84...?tl=g40c21s226
Old 03-29-2010
Ram sinks only needed for air. You should ALWAYS use VRM sinks.
Old 03-29-2010
thanks hc
Old 03-29-2010
i forgot to add
3m 8815/8805/8810 double sided heat transfer tapes....good to about -40C
Old 03-29-2010
i forgot to add
I use this sekisui #5760
No clue what the temp range is on it though.
Old 04-07-2010
V2-V3's Avatar
V2-V3 V2-V3 is offline
Asus Republic of Gamers
V2-V3 is on a distinguished road
def need VRM sinks, the cold will keep the RAM cool enough, also remember GPU RAM especially GDDR3 has a habit of not liking the cold. -60c and lower in most cases
"If it Doesn't Overclock its Broken!"
www.NexGenOverclocking.com
Old 04-07-2010
So just cover the RAM with eraser? Or leave the tops exposed.
Once the gpu pot gets here going to have to decide if I am going to DIce it or try LN2.
