Overclockaholics Forums » Hardware Section » Motherboards » Intel » LGA775 Dual Core board?
Old 03-18-2010
Kriztoffer's Avatar
OC Alliance
Default LGA775 Dual Core board?
Need help with LGA775 Motherboard for extreme overclocking.
I'm getting my replacement Intel Core 2 Duo E8700 back tomorrow. I already have a volt modded Asus Commando, but overclocking dual cores on that board will require some hilarious fast DDR2, since you can't change ratios.
I can get Asus Rampage x48 for 225$ New. They are normally 308$ in Norway.
I doubt my core i7 DDR3 stick will do any good on it, so then I will need some new DDR3, which can be expensive.
So going with a good LGA 775 board which supports DDR2 and good overclockability would be perfect.
Since I started overclocking around 7 months ago, I was never on the 775 platform, I jumped straight to 1366. So I can't say which boards are good and not. I've only been playing with my Asus Commando and Celerons.
But I've seen Gigabyte and Asus have had a lot of good LGA775 boards.
I need a list what to look for, I want some good boards, cause 10.5 x MP will require pretty high FSB.
*PS: Don't link me some Nvidia chipset board
Best Regards Kriztoffer
slipping the clutch
Old 03-18-2010
Best 775 board Ive ever had was the ep45c-ud3r 650fsb on stock northbrige cooler, takes ddr2 or ddr3 and loved my 2x1gb kit of hypers. This ud3lr is looking to be a good one though as well. Nice and cheap!
All stock MB voltages, put chip to 1.25vcore (no reason just though 1.1v was incredibly low lol)
http://valid.canardpc.com/show_oc.php?id=1085156
Has yet to fail
Old 03-18-2010
Kriztoffer's Avatar
OC Alliance
Sounds nice! how low VID does your E8700 got?
slipping the clutch
Old 03-18-2010
Kriztoffer's Avatar
OC Alliance
One of our internetstores in norway got Demo used hardware: the site is mainly in Norwegian, but specs and names are in English.
http://www.komplett.no/k/kl.aspx?mfr...By=p&zbo2=true
This is what I can choose from today, I don't really want to spend a lot on a 775 board.
Anything looking good there?
slipping the clutch
Old 03-18-2010
VID was like 1.1378
http://www.komplett.no/k/ki.aspx?sku=433162
http://www.komplett.no/k/ki.aspx?sku=344300
http://www.komplett.no/k/ki.aspx?sku=387020
Old 03-18-2010
Kriztoffer's Avatar
OC Alliance
I've been looking at that x38 board for a while, it seems decent. and got a good price
slipping the clutch
Old 03-18-2010
Gunslinger's Avatar
Overclockaholic
X48 Rampage Extreme FTW.
Old 03-18-2010
Kriztoffer's Avatar
OC Alliance
I'm worried about DDR3, will my GT's run it?
slipping the clutch
Old 03-18-2010
Gunslinger's Avatar
Overclockaholic
Yes GT's will be awesome in it. 6-7-6 or even 6-6-6
Old 03-18-2010
Kriztoffer's Avatar
OC Alliance
So I can run them at rated speeds? 2000mhz @ 1.65v?
slipping the clutch
