Overclockaholics Forums » Hardware Section » CPUs » Intel » Gulftown Overclocking/Performance Thread
Old 03-11-2010
Exclamation Gulftown Overclocking/Performance Thread
Lets keep this thread on track for all things and benchmarks run with Core i7 Gulftown Chips. Please note your chip specs in detail when posting, include screenshots as well.
I'll start out with all 4.5ghz runs using a Corsair H50 Cooler
980x Q3QP
E759
Windows XP SP3 vanilla.
GTX1 triple channel
wprime32m1024m: 3.624s + 112.077s
Old 03-12-2010
Lets keep updating our initial posts with benchmarks @ 4.5ghz, followed by ballz out sessions. Minimize the chatter, bumps are fine and will be merged as necessary.
Old 03-21-2010
lakeside2189's Avatar
Staying around 4.56 I did a primew32 run with the 1866 ram jacked to 2033....
This is embarrassing with you sub cold brothers but my best with the 975 was 5.450 sec with wprime32 on water....
This 287 batch chip is a beast....I can actually run 4.6++++ at under 1.40 cpu....
I saw this chip has a max of 1.40 compared to the 975 at 1.55.....
What is really my safe zone with cpu,PLL,QPI, Dram volts...
3.995 at wprime32 from this paranoid non-benching wipe just shows the power of the chip....
OS win 7 64
water cooled(see my WC in sig)
Batch # 3003B287
MB-Asus P6T7
My thoughts are this sucker runs extremely cool and is waiting for me to release the Hounds
Old 03-21-2010
Cooling - SS ~ -50C
Batch # - 3003A957
MOBO - Classified E760
Just my first few hours of testing, this thing is a beastly cpu but volts are high compared to the others here, this batch may be a dog.
On ln2 for the first time:
CBB: -135c
CB: -170c
Was running great up to 1.65vcc, but then whenever I tried to set more voltage, it would freeze. I think had I been able to go 1.75v+ it would scream!
Old 03-21-2010
I'll have to do some @ 4.5hz i guess.
Moving my info here so we can keep it and find it without searching 3 different threads. I'll make a ss of my voltages for this thread for reference also.
This is the not chitchat thread right? lol
Batch# B287
Drewmeister Phase SS
classy 759
dominator GT's
Win 7 64 on Vantage
Tiny XP 32 on prime
Tiny 7 32 on pifast (will be changing to Xp 32)
Old 03-21-2010
That's 4 Gulftown's in the house.
If you guys can be sure to go back and add the following info to your posts if its missing:
1- OS
2- Cooling
3- CPU Batch #
4- Motherboard
4- Personal Observations about Gulftown.
Old 03-21-2010
Still in box
Old 03-22-2010
1- OS
2- Cooling
3- CPU Batch #
4- Motherboard
Bump for more results.......
Old 03-28-2010
Bump...added a 3D06 run. With my 980x and a 8800gtx vmodded i wwill go from 45 th on the list to 7th. pretty sweet running 06 at 5167mhz on phase with 1.55 vcore and nt crashing.
Old 03-28-2010
Yes, very very good when compared to my ES chip, at similar speeds I would need about 1.62 - 1.64 volts @ -96c.
