RV790 Reaches 1.00 GHz, Indicates Overclocked SKUs in the Making
Following our report of ASUS preparing an overclocked Radeon HD 4890 accelerator with clock speeds well above 900 MHz (core) and 1000 MHz (memory), the possibility has come to surface that AMD has carved out a new range of Radeon HD 4890 accelerators from the unusually high overclocking headroom the RV790 GPU has. The credit also goes to the reference-design PCB, which is known to possess some of the highest quality digital PWM components to handle power, and 4 GT/s GDDR5 memory, which is now known to have a good overclocking headroom.
It has surfaced on the forums of Chinese tech community PCInLife, that the RV790 rather effortlessly reached the 1 GHz mark, the slider-limit of Catalyst Control Center, sparking off fresh rumors that AMD partners may be creating a fresh niche of highly-overclocked cards shortly after Radeon HD 4890 comes to be. The overclocker reached speeds of 1 GHz (core) and 1125 MHz (4.50 GHz effective, memory). At the said speeds, the card was put through 3DMark Vantage with its eXtreme settings. It churned-out a score of X5480, which puts its performance somewhere between those of the GeForce GTX 280 and GeForce GTX 285. It should also be taken into account that the drivers RV790 users the world over have been using, are preliminary beta drivers. AMD plans to release Catalyst 9.4 with the release of Radeon HD 4890, which just may impact positively on the performance of the product.
» Read full story Courtesy of Techpowerup.com
