Old 03-23-2009
Default Core i7 IHS removal
http://www.xtremesystems.org/forums/...d.php?t=222040
Pretty wicked ballz of steel to do this.
Old 03-23-2009
spfoam1's Avatar
spfoam1 spfoam1 is offline
Lurker
Holy crap......
I wonder how many he ruined to get that story right.
Old 03-24-2009
Nuckin Futs that guys is.... I don't have the nerve to do that but his on die water cooling is good stuff.
Old 03-24-2009
Thumbs up
Yep, for water cooling it should be a nice boost in performance and highest possible clocks on water.
Old 03-24-2009
Jeffro64's Avatar
Jeffro64 Jeffro64 is offline
DAYUM!
Old 04-20-2009
There are other ways to get that off without the lighter.....
1. After cutting, put it in the oven at the temp of the solder's melting point. I would wrap it in foil, then let it set in there for a few minutes and it should pop right off.
2. Uber-lapping. ...sand that bastard all the way down to the die. It may take a few hours, but you won't have to worry about cutting, solder, or making shims for the corners. :cool:
3. ...uh ...pay that guy to do it.
Old 06-28-2009
dinos22 dinos22 is offline
dinos22 is just getting started
i've missed this thread on XS but i havecome across others and the trouble was that there was hardly any improvements and the temp drop wasnt as drastic as this user "claims"
he didnt really provide any screenshtos of before and after which you'd expect to see in a thread like that
Old 06-29-2009
karmakazi's Avatar
Yeah for the potential gains vs the potential loses.... I would never do it.
Old 06-29-2009
limpkorn's Avatar
limpkorn limpkorn is offline
Junior Addict
limpkorn is just getting started
That's a preety nice boost down in temps! Might give it a try with C0 if I do end up picking up a D0.
Thermaltake Spedo Advance
EVGA X58 Classified NF200 Version
Core i7 920 4.4Ghz w/ Koolance CPU-350 Water Block
Mushkin Redline 3X2GB 2000mhz 8-8-7-24-T1 Kit
SoundBlaster X-Fi Titanium Fatal1ty Professional
WD 300GB 10K RPM VelociRaptor X2 in RAID 0
Seagate Barracuda 1TB HD
3XEVGA GTX 280 in SLI TRI-SLI w/Koolance Vid-428 Water Blocks
Ultra X3 1000W Power Supply
FPS X5 450Watt GPU PSU
G11 Gaming Keyboard G5 Gaming Mouse
Samsung Syncmaster 2493HM Monitor
Old 06-29-2009
crio's Avatar
crio crio is offline
I would only try it in my old pentium 4 630.But 30C under load is just wack.
RMA might be a slight problem for him.taunt
