Old 03-03-2010
Default Initial LN2 findings
Just ran my cpu pot on the advise of a friend.. good thing too cause I'm still dialing in the 975. I've had it down to -145C w/o hitting a cold bug and I can soft reboot at -136C. Hard reboot though i've gotta drop down to about -118C.
I'm thinkin those are pretty good numbers ???
Pot was pulled and is currently undergoing atmospheric normalization protocols .. will remount and drain the dewar later today
Old 03-03-2010
veddy nice! mine is similar but yours is a bit better at cold booting! -135c freezes windows (pun) -130 soft boot, -45c cold boot
Old 03-03-2010
Old 03-03-2010
So it is like Dice if you crash you have to warm up to boot ???
Sorry for the dumb questions never messed with this stuff
Old 03-03-2010
Yes
Some use a blow torch, I use a hair dryer. Don't do this with DICE ! the blow torch I mean ...
Old 03-03-2010
Originally Posted by Buckeye View Post
Yes
He He! This is a good advice!
Old 03-03-2010
2chesapeakes's Avatar
Those are great numbers compared to my 975. Cold boot -60 hard boot -45 and cold bug at -105. My 965 was worse than this w/ cold boot at -60 hard boot -40 and cold bug at -95.
Old 03-03-2010
Sounds like an excellent CPU!! Mine is kind of the same. No CB, is very picky about softboot, but will at full ln2, and hard boot at ~-74c. Mine don't count though since it's ES
Old 03-03-2010
Yes
Isn't that called "insta thaw process"
Old 03-03-2010
Insta that called "insta thaw process"
If by thaw, you mean FIRE, then you are correct. NEVER put a flame to acetone. I will never end the way you want
