Overclockaholics Forums » Hardware Section » RAM » Any New IC's Coming Out?
Old 03-01-2010
Question Any New IC's Coming Out?
Is there anybody "in the know" about any new kickass IC's coming out this year? I want to pick up a set of dom 2000C7's, but I don't want to buy them if the next week Micron comes out with some wicked fast chips. I want to buy the doms so I can compete in 2d.
BTW, anybody heard anything about the new 50nm Samsungs? Aren't they out yet?
Old 03-01-2010
Good questions Chuchnit. Ive been out of the loop on RAM for a bit but going to see what I can dig up. The revised cas 7 GT's are supposedly rock solid now.
Old 03-01-2010
What ever happen to that ultra low voltage triple channel kit I thought it was cas 8 1600 at 1.1v or something like that
Old 03-01-2010
Well I just don't wanna get stuck with a $400+ set of elpida if Micron is going to drop in with a new revision of D9's that own them. Know what I mean? Samsung was supposed to come out with 50nm DDR3 too. Must not be good clockers though.
Old 03-01-2010
Planet's Avatar
Planet Planet is offline
Planet is just getting started
Elpida is still the way to go if you want 2000MHz+ at decent timings. If you want higher speeds but loose timings you can get PSC D like Corsair's GTX1s.
Old 03-01-2010
Whoa I thought the Dom GTX's were super binned Hyper?? What about GTX2's? I'm more concerned about super pi 32m so +2000mhz and tight timings for me.
Old 03-01-2010
chuch gtx1's are high and loose for p55s sweet IMC (disclamer on Corsairs site says not tested on x58)
gtx2's are for tighter but lower frequency that x58 can handle. I have them on the way, will post results
Old 03-01-2010
Planet's Avatar
GTX2s are mostly if not all Hyper based GTX1s are PSC based. You would want the 2000C7s or the GTX2s. I wouldn't wait to long either.
Old 03-01-2010
You trying to say you are gonna buy the remaining stock? So basically these are gonna be the best thing since sliced bread for most if not all of the year?
Old 03-01-2010
Planet's Avatar
Yes, I am going to! Nah just saying might not be around much longer 2-3 months. As for whats going to come out who knows.
