Overclockaholics Forums » Hardware Section » CPUs » Intel » 22x Multiplier on i7 920
Old 02-28-2010
Default 22x Multiplier on i7 920
Someone asked about this last week? I can not find the thread at all (22x is not a valid search term)
Just thought I would start this thread and show that there is a glitch on some ASUS boards that allows 22X to be unlocked.
http://www.overclock.net/intel-cpus/...-920-into.html
Old 02-28-2010
disable some cores
Old 02-28-2010
basically max multi is being shown for core 0.... but not on all cores
Old 02-28-2010
I tried it on the Classy with no luck
If we could get it to work it would be a boost for everyones CPUZ validations
Old 02-28-2010
i have seen some boards taht will doo it....
try dropping down to no HT and 1 active processor (core) see if you get a higher opotion?
Old 02-28-2010
Tryed that as well as each one of the C1E options as well
I know it can be done as I have seem some on the bot
I will have to go back and see if it is a paticular board or BIOS ???
but 5.3/5.4 vilidations for all would be a blast ...........
Old 02-28-2010
That was the only way I could do it. (single core)
The link i provided shows it being done at 4core 8 threads
And try and try as I did to get CPUz to show 22x when I had a i7... I could not get it to do so (even trying things like loading core0 and then opening CPUz)
Easy to do on AMD not working for i7. :(
Old 02-28-2010
ive seen some boards pull the trickery, but its just giving you the reading of the single core. the rest of them are not at 22x
Old 02-28-2010
Nope.. but getting CPUz to READ 22x... reliably... would be huge
Old 02-28-2010
how about a 23x multi?
http://valid.canardpc.com/show_oc.php?id=970605
