Old 02-28-2010
Default ELEET issues
Having a problem with ELEET starting. Fresh XP SP3 install. I hit the exe and nodda.
Any suggestions so I can start rapin'?
Old 02-28-2010
Uninstalled, rebooted and then reinstalled?
Old 02-28-2010
nothing? usually takes a few seconds to load, but never had issues with it before. Maybe try a fresh download and install of eleet
Old 02-28-2010
Go to services and enable the 2 "windows management" services.
then it should start.
I set them to start automatically.
Old 02-28-2010
all refreshed, new version installed, and reinstalled. I'll try Dents suggestion and report back. Thanks for the quick replies fellas.
Old 02-28-2010
hmmm, no management services....guess that's the problem lol.
Old 02-28-2010
Eleet does not work on my install of XP from day one
I have just been booting into the speeds I want
I have some bullitproof 5.0 boot settings if intrested
Old 02-28-2010
ELEET has always been slow as molasses to load for me regardless of OS, but it always does eventually.
Old 02-28-2010
Rev are you on your own cut down XP install? I've never had a problem with eleet, other than its slowness on every OS. I have used eleet on about 15 different cutdown OS's without problem.
Old 02-28-2010
Kriztoffer's Avatar
OC Alliance
yeah, when you tweak services there are always certian risk for programs not running propperly.
slipping the clutch
