Old 02-23-2010
Default LN2 @ vantage = Fail session
Okay so I have 3 different vantage runs here.
Temps: -105c to -110c constant tonight
(last night I thought I was t -135 -140? now it freezes when that cold)
24357 1370/1200 1.5v 4.96ghz x16 uncore (last night)
24216 1320/1200 1.45v 5.18ghz x20 uncore (tonight)
24039 1330/1200 1.5v 5.21ghz x18 uncore (tonight)
I thought it was maybe overvolting or error correcting last night so I lowered the volts on the gpu and clocks and the scores are worse. Makes sense right?
CCC
CAI advanced
Triple buffering unchecked
Perhaps I just need to reinstall windows? is dual channel killing my score?
No sinks on the vrms an issue?
Old 02-23-2010
Dunno about 5000 series but my 4890 VRMS got hot hot at lower volts then that until I fixed the heatsink... I would have sinks on the VRMs before I put them on the memory.
But I also do not know how well the cold radiates off the GPU pot.. VRMs are back kinda far from the GPU though I thought... couple inches at least.
Old 02-23-2010
Gutterz's Avatar
Gutterz Gutterz is offline
ya u need sinks on the VR's I was told. Nice scores by the way!
Old 02-23-2010
I would think that Vantage would like triple channel better since it responds so well to bandwidth but I've never tested that. The other side of the coin is higher cpu clocks with less triple channel load on teh imc which would net higher scores me thinks.
What temp reader/probe you using? Sounds like it sketches out under -100c. Have you tried 06 to see if the card clocks are funked?
Shammy always makes it point to get sinks on vrms.
Old 02-23-2010
RomDominance's Avatar
Has to be the triple channel situation Splig. Your cpu scores are a full 1k higher than mine.
Old 02-23-2010
Mem & uncore look low. Images are hard to read thou.
Old 02-23-2010
uncore was 4200 OC
kal temp probe was the standard one that came with the extech. Im thinking its freaking out because Im using both inputs?
I will try to get some sinks on the vrms, and 3x2gb kit of hypers are in transit to rule that out.
Old 02-23-2010
106k in 03 at 1330/1200 1.45 so thats seems pretty on point no? Cpu 5.28
Old 02-23-2010
Down right sick brother.
Old 02-23-2010
Nice, you nudged out your romulan buddy but its all good in the oca hood
