Old 02-01-2010
Default Xtreme w3570 by the K|ngp|n
Old 02-01-2010
That Vcore is unbeleivably low
he must have like zero resistance to run at that
the bar is high indeed
Old 02-01-2010
Nah that has to be a glitch in cpuz. I remember it would do that sometimes when using setfsb on the 775's.
Old 02-01-2010
or he finishes the run then lowers the voltage with evbot for the SS
It wouldnt be the first time clock speeds or voltages were modified for the validation
Old 02-01-2010
Yeah I think that stuff happens a lot more then people know, just to make there CPU and there skill seem really good.
It's like... Oh Yeah I got 5.2ghz at 1.2vcore on Air Cooler, what you can't get even close to that ? your OC skills must suck baddly.
Old 02-01-2010
I always assume that people that post low voltage score or talk about 24/7 stability are either
a) Lying for ePeen
b) have some other voltage jacked up too high to compensate. (like PLL or on the 775 GTL REF)
The only reason I pay any attention to volt posts is I do not normally buy good motherboards. Lower quality FETS means less maximum wattage
Old 02-01-2010
What? That's horrible! What kind of monster does that to people?
Oh thats right, steve used to do that to me all the time, hahahahahahah
Old 02-01-2010
k|ngp|n's Avatar
k|ngp|n k|ngp|n is offline
OCA VIP
k|ngp|n is just getting started
Its becuase its an older version of cpuz that reports vcore wrong
Old 02-01-2010
ahhhh.... sheesh even the master nubs it up occasionally
Old 02-01-2010
k|ngp|n's Avatar
OCA VIP
Whatsup!
Nah that was intentional
