Overclockaholics Forums » Cooling Performance Section » DICE & LN2 Cooling » DICE Session [Classified, 3x 5870, 920, GT, Commando ++]
Old 01-16-2010
Kriztoffer's Avatar
OC Alliance
Default DICE Session [Classified, 3x 5870, 920, GT, Commando ++]
Me and my friend teamed up yesterday for some benching.
Setup:
- Classified E760
- 920 D0 @ 5Ghz on DICE.
- Dominator GT 2000 CL8
- 2x PowerColor 5870 and XFX 5870 with MSI unlocked BIOS.
- Corsair HX1000
- Kingpin F1 EE
775 Setup.
- Asus Commando volt modded
- OCZ Flex 9600 2GB
- Celeron 347
- TX750
- Sapphire x1600 Pro for screen.
- Kingpin F1 EE
- Swiftech NB block cooled by TFC Monsta. Overkill
Here are some results from yesterday. We used about 10KG of DICE. We had a few problems booting the Commando and a lot of "FF" on the Classy. I used the settings for lowering the Coldbugg, but it still posted a lot of FF. X-Cool was moved to right positions and I followed a few tips from Shamino.
Anway, we had a really good time. And are kind of happy about the results..but I really don't know why we couldn't reach 5.1 ghz with a XP disc. Cause it was stable enough running 5.1 in 06, but gave lower score since DICE ain't cool enough.
Anyway, we are very happy that it was good enough to bench 3D's at 5Ghz on DICE.
Photo's PS: That is my friend not me.
slipping the clutch
Old 01-16-2010
Sick 3D scores bro!
The wprime looks borked, how many times you guys run it? Which os? I know it should be lower.
Old 01-16-2010
Kriztoffer's Avatar
OC Alliance
Sick 3D scores bro!
Yeah, I was thinking the same:S I ran it once..I was so tiered. We just wanted to try a few Wprimes and a SP1M..
slipping the clutch
Old 01-16-2010
Thatst prolly it. Sometimes you'll get your best score between running 1 and 4 times and sometimes it'l take up to 8 consecutive runs to find your best time. All depends on what it wants to do at the time.
Old 01-16-2010
Kriztoffer's Avatar
OC Alliance
Thanks mate! I'll remember that.
slipping the clutch
Old 01-16-2010
Nice runs man
Old 01-16-2010
5ghz 3D bench runs with that 920 is nice work on DICE.
Old 01-16-2010
Kriztoffer's Avatar
OC Alliance
Nice runs man
Thanks mate!
Yeah, I think so to. So the chip is pretty good imo
slipping the clutch
Old 01-16-2010
Nice! That's scary business you have going on there with all the eraser around the socket opened up. Be careful man.
Old 01-16-2010
Yea that 32m score is off
mine did 5.11 @ 4.7ghz, i was using XP 32bit
http://hwbot.org/community/submissio...920_5sec_110ms
Sick scores on the others tho, i can only wish to break 5ghz on any chip right now
