Old 01-13-2010
Gutterz's Avatar
Gutterz Gutterz is offline
Default 920 dice session
First off for starters this is my second ever Dice session so dont bash to hard.
I7 920 C batch dice, 5870 on stock hsf, was suppose to be water but the card wont post with the block on so I moved on. Evga Classy 759 S22D bios, stock hsf.
Detroit A/C pot -59 is all it can hold . Super Talent Chrome 2000mhz Ram.
Cool air for the 5870
I was hoping more from this session but sometimes it dont work out, Hopefully I can get a colder solution soon. Im going to inspect this waterblock card issue in the next day or so.
Cheers
Old 01-13-2010
Looks pretty good I am certainly jealous.
Might want to rerun 3d01 though. Your score should be up in the 90+K area with those clocks
Old 01-13-2010
lakeside2189's Avatar
Very Nice!!!!
I want to learn.....
Man, you are rolling!!!! A star is born!!!!!!
Old 01-13-2010
RomDominance's Avatar
Nice work dude. Not to far off from my 920 dice session last weekend.
Old 01-13-2010
Gutterz's Avatar
Ive tried that 3D1 several times. I dont know whats up. My 8800 GTS 640 is on the 5870's ass lol
http://hwbot.org/listResults.do?user...pplicationId=1
I had to keep moving I was more interested in my Aq3 06 Vantage an Wprimes.
It wasnt cake I F'ed up more display drivers than you can shake a stick at. Uh god the insanity Afterburner would boot some crazy shit when windows started an I didnt even have it set to autostart.
Thanks Lakeside.
Old 01-13-2010
Chances are your multimeter is reading wrong as I had the exact same one and it misread by 12 degrees or so. For the life of me I couldn't figure out how everybody else was getting temps of -65 to -70 on DICE but I couldn't. I tried everything but no luck. It wasn't until I bought my UEi DT302 that I realized that the other was misreading. -59 was the lowest I achieved on that multimeter. With the UEi I was getting temps -70 to -75.
Nice runs though!
Old 01-13-2010
Gutterz, super scores buddy. You are just killing it lately on the bot!!
Try running 3d01 in XP. Scores should improve ALOT!!
Old 01-13-2010
Nice work !
DICE can be tricky. What I do is put a fair amount of Acetone like you did, bust up that DICE into a powered and add that slowly. It will foam up a lot at first.
When it gets down to temp you can start added a bit more.
Using big pieces of DICE does not really cool that well and clogs up the tube, power works best.
I do put a few small pieces of DICE in when the temp gets down but not very much.
I have only used the F1 & Tek Wide Mouth for DICE and its pretty hard to do with those because of foaming issues.
Old 01-13-2010
Gutterz's Avatar
Nice runs though!
Yeah you said it wasnt bad for the money which its not. It works great for the chiller or just an Idea of temps. I seen 60 for a split second when I had the pc off an was trying to get it colder but no dice lol
I didnt have 01 installed on xp I should have but didnt. I got to go an sweep all my Os's. Vista is fubard for some reason with display issues.
Old 01-13-2010
very nice job bro.... looks like you ate that thing up
