Overclockaholics Forums » Cooling Performance Section » Water Cooling » Possibly the simplest water-cooling question since the last Ice Age
Old 01-10-2010
LiquidNitrogen
Guest
Posts: n/a
Default Possibly the simplest water-cooling question since the last Ice Age
OK, no laughing now.
What is put into those tubes to make them all glow in the dark with so many cool colors?
I said no laughing!
Old 01-10-2010
It is not normally the liquid, but the tubing itself that is uv reactive.
Old 01-10-2010
Gutterz's Avatar
Gutterz Gutterz is offline
you can get dye, but it can stain tubes an clear resevoirs Ive read.
Old 01-10-2010
Jeffro64's Avatar
Jeffro64 Jeffro64 is offline
Plus dye can clog up the system i've heard... UV would be the way to go.
Main Rig
Case - Cooler Master Cosmos S
PSU - Corsair HX1000 1000W
DVD - LG 22X GH22LS30
OS - Vista Ultimate 64bit
Old 01-10-2010
Dunno if this still works but you can whipe some Tide detergent on your tubing and it'll glow under a UV light.
Old 01-10-2010
LiquidNitrogen
Guest
Posts: n/a
Thanks for the replies. Glow-in-the-dark tubing, who would'a thought!
