Extreme Overclocking No Air Or Water... |
01-01-2010
Amd 965be+790xt-ud4p+ss
Hi guys,
havenīt any AMD CPU for 5 years ago. Now I bought one and started to test.
Here are my first results with little cold (-40 +/-4c).
Components used:
AMD Phenom II X4 965BE C3
Gigabyte 790XT-UD4P
2x2GB Kingston HyperX KHX1600C8D3T1K2/4GX
Have tried the CPU-Z validation and SPI 1M test for first
CPU-Z - 5176,79MHz
http://valid.canardpc.com/show_oc.php?id=919998
SPI 1M - 13,797s(CPU-5037MHz, Mem-876MHz Cas8-9-8-24-40-2T)
The results are not final, I see a little improvement - time to play
Tommorow I will test some 3D stable frequencies too. So stay tunned
MSI P55-GD80, i7 860, 2x1GB KHX1600C8D3T1K2/4GX, Inno3D GF 6600 128MB, Sapphire X1600Pro 256MB DDR3, Asus EN7900GS 256MB R.I.P., Leadtek Winfast PX9600GT 512MB, Asus 9800GT TOP - prepare for RMA, MSI N260GTX Lightning, Akasa 1200W 80+, iiyama ProLite E2208HDS
01-01-2010
Looking very good bro, can't wait to see what numbers you can pump out on 3d benches
Total Threads = 12
01-01-2010
5ghz+ Club
01-01-2010
Nice clocks there on SS Phase
01-02-2010
Thanks
some results wprime 32M, 3D mark 06 and 05
for 3D tests I used an MSI N260GTX Lightning VGA for now at default frequencies
wprime 32M - 4752MHz (7,828s)
3D Mark 06 - 20633Marks(CPU skore 7166 points) (CPU-4725MHz)
3D Mark 05 - 28046Marks (CPU-4752MHz)
The frequency of CPU while 3D Mark 05 could be a little improved because of better CPU temps while the mark is running. For 3D Mark 06 and Wprime 32M it looks like its the max for the CPU at these temps vs. voltage.
Now working on 3D Mark 03 and SPi 32M
01-02-2010
Really good runs bro. Are you going to be running 3DMark with some better GPU (s)?
Total Threads = 12
01-02-2010
Thanks,
for now only my best vga at home is this Lightning(will to OC a little), now iīm low on budget so better VGAs maybe in a mounth or so.
01-02-2010
Originally Posted by 0Ro!
Thanks,
What are you looking to get?
Total Threads = 12
01-02-2010
a small update
OCed the VGA to 792core/1584shader/1050memory and a little CPU frequency improvement
3D Mark 03 - 63535Marks (CPU-4837MHz)
3D Mark 05 - 30276Marks (CPU-4837MHz)
the OCed vga with the same frequency of CPU maked 2K points more in 3D Mark 06, but havenīt the screenshot because it was corrupted - only the upper half of screenshot is seen
im thinking about a 2core VGA like 295GTX, 4870X2 or something like this
01-02-2010
Nice improvements.  . You should try a 5970 if the funds allow.
Total Threads = 12
Copyright Đ2009-2014, Overclockaholics
