Hey guys... I have a older puter here that I put together cheap for my mom long ago. It is an ABIT NF8-V board with a AMD Sempron 2800+ CPU installed.
My mom just got a new puter and wanted me to fix this one up for my dad, so I put a few new parts in ( GPU, New PSU and more ram) and installed Vista Ultimate 64. The CPU is clocked at 1.67Ghz and was having anything to do with being OC'd very much without getting the good ole BSOD, so I thought I would upgrade the CPU a bit to have Vista running a little better. NOTE: It ran much better when OC'd but was having the BSOD's.
I have found two Athlon 64 chips for cheap but I wanted to see what you guy's thought about which would be better and might OC better also. There are differences in speed on the Mhz and on the HT Mhz so I wanted to run it by y'all first.
Here are the two i'm looking at.... And thanks for any help you can give!
1.
AMD Athlon™ 64 Details
Processor AMD Athlon™ 64
Model 3200+
Part# ADA3200AI04BX
Operating Mode 32/64
Stepping E6
Frequency 2200Mhz
HT Speed 1600
Voltage 1.40V
Max Temp 69°C
Thermal Power 59W
L1 Cache 128KB
L2 Cache 512KB
CMOS Technology 90nm SOI
Socket Socket 754
2.
Type Microprocessor-AMD ATHLON 64 3400 SOCKET 754 NewCastle
Part number ADA3400AEP4AX
Processor core NewCastle
Manufacturing process 0.13 micron SOI
Data bus width 64 bit
Package 754-pin lidded microPGA
1.57" x 1.57" (4 cm x 4 cm)
Socket Socket 754
Speed (MHz)
3400+ (rated)
2400 (real)
Stepping codes ABASC CBAEC CBASC CBAXC CBAZC
On-chip peripherals Single-channel DDR SDRAM memory controller
One 16-bit HyperTransport link with speeds up to 800 MHz
Low power features System management mode
Halt state
Stop Grant state
Other features MMX technology
SSE
SSE2
Physical memory 1 TB
Virtual memory (TB) 256
Level 1 cache size 64 KB 2-way associative instruction cache
64 KB 2-way associative data cache
Level 2 cache size 512 KB exclusive 16-way associative cache
Floating Point Unit Integrated
V core (V) 1.5
Max operating temperature (°C) 70
Thermal Design Power (W) 89
