Overclockaholics Forums » Hardware Section » GPUs » ATI » 5770 Review UNDERCONSTRUCTION
Old 12-20-2009
Default 5770 Review UNDERCONSTRUCTION
5770 Review
INTRO: Today i will be reviewing the XFX 5770 v1 ( HD-577A-ZNFC ). This is the first of the mid-ranged gpus featuring Full Dx11 compatibility and Ati's Eyefinity Technology. Eyefinity lets you use 3 monitors on 1 card, which give you a wider view in games and Multi-Screen setups for the office. This card comes clocked at 850mhz which is the same as both the 4850/4870. The memory comes in clocked at 1200mhz but since it's GDDR5 its quad pumped making the Memory data rate 4.8 Gbps.
PIC OF BOX FRONT
PIC of BACK
PIC OF CONTENTS INSIDE
This Card came with the following:
1. Quick installation guide
2. Driver CD
3. A molex to 6- pin Adaptor for old power supplies
4. DVI-to-VGA adaptor
5. CrossFire bridge
6. A “do not disturb” sign.
Closer LOOK AT THE CARD
This card uses the original version 1 cooler that directs heat outside of the case, and keeps the Card at very Decent Temps.
This card has 2 dvi ports , 1 hdmi and 1 display port. The 5xxx series cards allow you to use up to three video monitors at the same time as a single desktop, feature known as eyefinity. Eyefinity is only able to work if 1 of the monitor has a Display Port or you can purchase a separate Active DisplayPort Adapter.
This Card uses 1 6-Pin power.
Test Setup:
965BE @ 3.4ghz Cooled by Thermalright TRUE 120
Crosshair Formula 3
2gb of G.Skill DDR3 1600
30gb OCZ SSD
300gb Velociraptor
750tx Corsair PSU
OS - Vista/Win 7 32bit
CCC 9.12
PIC OF THE TEST BENCH
Benchmarks EVERYTHING STOCK
3dmark 03
3dmark 05
3dmark 06
3dmark vantage
DX11 Benchmarks
Heaven
Tropics
Sanctuary
Game Benchmarks
Street Fighter 4
Overclocking the 5770
I used CCC to overclock the 5770.
Same BENCHMARKS OVERCLOCKED SETTINGS
CrossFire X Scaling
3DMark 03 Stock
3DMark 03 Overclocked
3DMark 05 Stock
3DMark 05 Overclocked
3DMark 06 Stock
3DMark 06 Overclocked
Vantage Sock
Vantage Overclocked
Game Benchmarks
Street Fighter 4
Stock
Overclocked
Final Thoughts
Old 12-21-2009
Ok i started on the Crossfire results first since both cards are in my system already.
Do the overclocked scores look too low ?
Old 12-21-2009
Chicken Patty's Avatar
Looking good so far bro
Total Threads = 12
Old 12-21-2009
Looking good bro cept I'm not familiar with that combo of hardware, especially the amd cpu stuff. Have you compared it to the bot?
Old 12-21-2009
Looks like a good outline for a straight up review
Comparisons are nice, but not really important
Old 12-21-2009
everyone on the bot is using the x58 platform for submissions on 5770 CF
I need to do the single card tomorrow and see how that goes
Trying to do this for the ces application thing, if i don't have to pay then i'm going
oh and i got some boints on most of the CF submissions
Old 12-23-2009
With some help from a friend i got some updated pics and a little better intro and some more info
does it look good so far ?
Old 12-23-2009
Sure is a short card. Nice write up. Your well on your way. Nice wallpaper!
Old 12-23-2009
Good going Juan, loving the new pics and intro
Total Threads = 12
Old 12-23-2009
Lubbin the oca banners!
