Overclockaholics Forums » Hardware Section » RAM » Corsair dominator 3gb
Old 03-15-2009
Question Corsair dominator 3gb
http://www.newegg.com/Product/Produc...82E16820145225
Thoughts? Recommendations? I only want 3 gigs as I don't due anything to require more than this and 3 gigs will overclock better than 6 gigs.
Old 03-15-2009
Corsair has listed the IC's used in each of their kits. I know i4memory has the list. Actually the new 3x2 kits are clocking like crazy though.
These right here are either Samsung HCFO or the new 50nm Eldipa IC's that are crushing super pi records. Both IC's are sweet chips. These aren't much more either.
http://www.newegg.com/Product/Produc...82E16820104082
Old 03-15-2009
Can't you use these in a x48 mobo? Thought I read somewhere you can use these modules on the older boards too?
Old 03-15-2009
Yah but I haven't found any threads from people stating that they still perform at the low volts. The Samsung HCFO IC's were used before i7 anyway. As a matter of fact, they were in alot of the top 2000mhz kits.
Old 03-16-2009
Thanks for that tid bit chuchnit I will look into that RAM.
Old 03-16-2009
Glad I could help
Old 03-18-2009
skarface's Avatar
skarface skarface is offline
skarface is just getting started
Dang thats insane i didnt realize how much ddr3 dropped!
raid 0 seagte baracuda 320s
seagate baracuda 500 gig
x58-ud5
sli gtx295
i7 920 do step5
1200 xclio
mushkin redline 6 gigs (pc 16000)
corsair dominator fan
2 koolance reservoir 1 magicool reservoir
2 cpx pro pumps
koolance 330 cpu block and koolance video blocks
stealth ice gt triple rad
black ice steal gtx extreme 240
heatware
Old 03-18-2009
The 3x2gig sticks are the Eldipa IC's but they are never in stock. I am afraid to get those I will have to have the $250 sittin on the side line and be ready to jump. I signed up for notify me when in stock so we will see.
For those that are up to par, Eldipa IC's are the same which are used in the Corsair Dominator GT 7-8-7-20, OCZ Blade PC3-16000 7-8-7-x and G.Skill's Perfect Storm DDR3-2000 7-8-7-x. eva2000 brought me up to par over at Xtreme on this.
http://www.newegg.com/Product/Produc...82E16820104084
EDIT: Went to Kingston's site and they show them to be out of stock until 6/10/2009!!!! Just going to have to get the Corsair's for now and maybe in the 3 months prices will be down on them and they will be in stock.
Old 03-19-2009
After combing the web there is no real proof of whether the Kingston HyperX 3x1 gigs are Eldipa IC's or not. One site referred to them as being it but who knows. I know the 3x1's are cas 9's while the 3x2's are cas 8's. I would have preferred to had the 3x2's but they are out of stock and no tellin when they will be in stock. All I know is my mobo and cpu will be here the 1st of next week so I went ahead and ordered the Kingston HyperX DDR3 2000 3x1 giggers!
Old 03-19-2009
Sweet!! Either way they should be top notch IC's.
