Overclockaholics Forums » Hardware Section » GPUs » ATI » HIS 5970 Action
Old 12-12-2009
Default HIS 5970 Action
Stay tuned
Gonna bench these things on air tonight
CPU i7 920
E759
Gskill 2133 cas 9
(2) HIS 5970's Cat v.8663.1_Beta5_Hemlock_Win7_Nov11 for 7x64
The test rig:
Initial temps around 51c on the cards and down 10c when fan speed ramped to 100%
Old 12-12-2009
I have to say this..
I'M JEALOUS
now that we got that out of the way, when will you post up some scores with the you-know-what on the 4-way classy. PLZ let it be later today or the latest tomorrow
Old 12-12-2009
You aching for gulftown runs? I'll get to it asap, just happy to be messin with hardware for once.
Old 12-12-2009
cant wait for the runs !
Old 12-12-2009
The Test Rig:
Old 12-12-2009
sofos1990's Avatar
WOW!!!!
Good luck with your new toys Kal-EL
Old 12-12-2009
Thx sofos......
Not to bore anyone but I gotta re-image my 6-OS boot partitions to have a clean go at it. Should take about 10 more minutes or so using Terabyte Unlimited's Image for Dos. I have the entire thing on a spare sata drive and its imaging byte for byte each of the six os paritions that each have all benchmark apps installed, fully updated, activated and without video drivers so I can easily switch between different cards. If you're interested in this software, follow the link on the sidebar to the left.
My bad, it took a lil longer than 10 minutes to image a 6 boot loaded, 6 paritions fully loaded with all benchmark applications installed on each os. Best look for another back-up software cuz this one is getting too slow
Onwards to ATI HIS driver installation in Win7 or does anyone suggest Vista play?
Old 12-12-2009
Ooops, looks like I goofeded
The i7 920 is in the socket rather than the 3570 Oh well, we'll work out my blck suck
Old 12-12-2009
That's what I am talking about.
You have a longer bridge so you don't have to run them so close?
Old 12-12-2009
No I don't have them long bridges but I believe its x16 x16 in this config, not sure about the E762 tho (anybody know off hand?)
