Old 03-14-2009
Gutterz's Avatar
Gutterz Gutterz is offline
Default Avatars
Do regular members get avatars or just mods? Cause I have no option for one.
Old 03-14-2009
Your avatar works but you didn't have one assigned. The one I put for your avatar you had assigned to your Profile Picture. Didn't know if you wanted it as an Avatar but I put it there for you. I did notice that you are not able to display images in your sig. I take your exact sig and put it mine and it displays images.
Old 03-14-2009
Gutterz's Avatar
Thanks. I dont see an option to assign an avatar. What is it under?
Old 03-14-2009
UserCP
Old 03-14-2009
Gutterz's Avatar
Ive checked user cp their is nothing their nor under each tab. I dont think regualr members are able to. No other regular member has an avatar besides me now
Old 03-14-2009
Well I can't call it as in the admin panel it shows that members have the Avatar listing in their Usercp. The important thing is you have one now.
Old 03-14-2009
budderbeans budderbeans is offline
budderbeans is just getting started
Sure enough it isn't there as a regular member. Supes any insight on this?
Old 03-14-2009
Fixed Avatar uploading and sig pics
OCA Gladiators have special permissions, includi albums, animated user pic, avatars, albums, social groups, visitor messages, Sig pic, animated sig pics, enhanced pic size etc.
The average joe will be limited.
Thanks for the headsup Gutterz
