Overclocking Air & Water...
Old 11-24-2009
Cecil Cecil is offline
Cecil is just getting started
Default W3540 and EVGA 3X SLI
Got it in Linx testing now to check temps and stock stability. 133x23 1.25 vcore, 1.2VTT. Load hit 55C so far with all ram tested.
I am aiming for 4.5HT for the harder benches (3dmark, SPi 32m and wprime 1024m) and 4.6HT for the rest. Once I get another rad in the loop should get another 100Mhz to each.
Ive got to bench my 4670 to death today, then Ill get the 285 in. Going to try messing with the 9600GSO to 8800GTS 512mb mod later this weekend.
New Sig To Come
Old 11-24-2009
Good clocking to yah Cecil. I've got a 9600GSO around here someplace, the 1gb variety.
Old 11-24-2009
Not sure if they flash or not. I know it has to have 8 ram chips, and be 96sps.
208x23 no ht, and 200x23 2d benchies are done.
New Sig To Come
Old 11-24-2009
Benches. My Spi 32m sucked for some reason.
New Sig To Come
Old 11-24-2009
I think XP would run them primes a tinsy bit faster.
Old 11-24-2009
What is the benefit of flashing a 9600GSO to a 8000GTS is they have the same amount of Shaders?
EDIT: NM I see it unlocks shaders
Old 11-24-2009
9600GSO is SPs and 192bit
8800GTS 512 is 128SPs and 256bit
Also OCs the core to match the 8800.
New Sig To Come
