Old 11-23-2009
lakeside2189's Avatar
Default 5870 test
Just got a hold of 3 of the Asus cards..Demo stuff..My pockets are not that deep...These are the best made and looking big cards i have ever seen..Don't have to worry about these bending on ya in a case even at 11 inches long..It seems all cards have there Futuremark test they like the best...I haven't tweaked the cards at all..Just wanted to see how they would run....Beat my 3D03 score with 2 4870x2's maxed at 4.600...Will try more things later...
Old 11-23-2009
Excellent!
blow up some benches bro.
Old 11-23-2009
These really are a major improvement as far as sound and temps over the 4870x2..Took 1 out and ran 2 for 3D06...2 of these beat my top
x2 and I havent choked the cards at all...Not really sure about tweaking the voltage but will figure it out...Kal? This is at 4.5
Old 11-23-2009
still running cards stock..Beat my 3D05 score with 2 of the 5870's.....Better than 2 of the 4870x2's...ran these at 4.600 with ease....Must try the voltage tweak and could use some advice before i blow these pretty things up...
Old 11-23-2009
RomDominance's Avatar
Very nice Lakeside, I would love to get my hands on a few of those! Where are those heading once your done? They would do real well with my W3520 in front of em @ 5GHz.....one can dream.
Old 11-24-2009
Actually sending 2 of these to a friend at the forum..I am assured the 5890 will come after fermi...With the new bots ruling I will wait on those.I also can't fit the 5970 in my case..These just fit...Do you run that 5.0 on H20??? Just wondering...I can't get over 4.625...It could be me!!!!
Old 11-24-2009
Nah bro, SS. When I had my 920 on water, I was limited to 4.65 as well.
Old 11-24-2009
very nice runs bro
got the big guns.... tahts what i need are gpus
Old 11-24-2009
Thanks bro, I am really just a beginner.. 1 year old OCer..But I like to learn and I'm not scared...Maybe thats not such a good combo!!!
Old 11-24-2009
FYI, the latest afterburner version has the ability to remove the ccc clock limits. I haven't used the latest version yet but the info is out there.
I'll dig up my screenshots with the old afterburner open and showing the settings and post it here when i get back from work.
