Overclocking Air & Water...
Old 09-30-2009
Cecil Cecil is offline
Cecil is just getting started
Default Another 920 Build
Back to i7, for the third time.
920 D0
UD3R rev 1.6 (at ewiz now for $141 shipped after MIR, promo code and BCB)
Hunting down ram
GTZ / MCR-220 w/Res / Apogee Drive modded to MCP-350 with 355 solder mod and XSPC top
Last rig with the R2E was able to validate 4.8HT. I have a smaller rad, and no AC pointing at it this time, so my goal is to match that
Aiming for 4.4HT 24/7 stable. This is going to be my final gamer setup. Grabbing a 5850 in a couple weeks when I recover from cost spent on this and my HTPC.
Old 09-30-2009
Looking forward to any tips or tricks
Old 09-30-2009
Decided on 6gb Kingston HyperX 2000Mhz kit. Should have everything by mid next week.
Old 10-05-2009
Ewiz took their time shipping the board, then sent it the see you next fall method. But heres everything else ready for it.
Old 10-09-2009
Those bastards at ewiz sent me a revision 1 board. However, it has the option to go to 150 PCIe. I wonder if it actually works?
Old 10-10-2009
Wow uber cheap mobo. Could have stepped down on the RAM to grab a better board. I am having some regrets spending only 125 for my X58 board. 220 bclock is a bitch to get stable (but I have had almost no time to play with it :( ). Once I have time to dedicate to it though, I wil invest in something better (Hey maybe I will be ale to a classy in the 200 range by then )
Old 10-10-2009
Its cheap, but aside from the classy, its the best one for getting past 222BCLK (if its revision 1.6 like it was supposed to be). The 1.6 has the PCIe mod so all you have to do is change PCIe and you can boot over 230BCLK.
And the difference for 1600 to 2000 ram is only $30 or so now.
I got 4.2HT stable with ram at 2000Mhz 9-9-9-27 stable first try. Temps are loading at 83C with Linx. Working on higher speed and lower voltage. Only the ram doesnt want to go as high as 2050.
Old 10-11-2009
Well, I got 4.2 WAY lower lol.
Still havent bottomed out yet either.
Old 10-11-2009
Wow, thats nice Cecil, great work dude, whats you're other voltages like? or is it set to auto?
Old 10-12-2009
1.395 VTT, 1.66Vdimm, auto everything else. Vcore is at 1.3, still testing lower. Going to lower the ram multi to get the VTT down.
