Overclockaholics Forums » Overclocking Section » Overclocking » x58 platinum 920 D0 A stepping PAtrioit Extreme Viper 3GB 1600
Overclocking Air & Water...
Old 09-30-2009
Default x58 platinum 920 D0 A stepping PAtrioit Extreme Viper 3GB 1600
Starting off with some pics
From unpacking to first setup to modifications. I added some stiff paper to the side of the hammer for better air flow control, (Have not tested effectiveness yet) and a fan to help cool the blazing hot chipset (will re-TIM it later)
Old 09-30-2009
HAve not stressed Mem yet
Currently running
200x21 +.1v (1.325-1.35 effective)
1600 MHz Mem speed at 1.65 volts. Gogin to get this closer to 2K
4890 at 1000/1125 for an AM3 run at 50% fan speed
Soon as a I figure out how to change TGA to PNG I will upload my 280k result at the bot. Its low and no boints, but its a start
Old 09-30-2009
First results. 6.968 seconds wprime 32
215Seconds 1024Wp
first sub 10 second spi1m
32M pi crashed the PC. Upped vcore to ~1.4 and trying again (untweaked OS mem at "stock") lol was 1.375 instacrash though
retrying now at 4190 220*19
Old 09-30-2009
Well going to have to spend more time on this. It is no 775 for overclocking for sure. Hopeing it is more like AMD, take care of themem and the IMC and then worry about core.
Going to play around some more in the 4+ GHz range and try and figure it out
Temps are amazing even at 1.4vcore though. Cant beleive people say these run hot *pshaw
(course modding the hammer really helped. I think it dropped temps at least 5C maybe more like 10 )
Old 09-30-2009
I know you told me already but I forgot, how'd you mod the Hammer again?
Oh and keep pushin Neuromaniac
Old 09-30-2009
You got PM bro, hope it helps.....
Old 10-01-2009
thanks banik. Think my kids are throwing me a surprise party tonight, so no more OCing for me today :(. Got a little frustrated last night trying to run 32m at 4.2HT. And drank some more beers instead of working on it lol
I might not be juice happy enough as your PM after reading your PM, temps were reasonable so far though with the slight increases I was giving it. wprime 1024 only heated it up to high 60Cs.
As for the hammer mod I noticed when it was running that a LOT of air was gushing out the sides. More than out the back of the heatsink. My aunt got me a little birthday card from the store (real small one) I just ripped it in half and taped it to each side so the air is forced to pass all the way through the heatsink and most importantly, reach all the heatpipe connections.
It definitely seemed to help and when I next have some free time I will take the board out and redo the NB heatsink, and mod up something a little more permanent for the hammer. I would also like to get another panaflo on there And some more xigmatek fan mounts. I have a battle axe cooler sitting here un used that I took the fan mounts for.
Something that just drops over it and could double as a shroud right out the cases rear exhaust (I am sure someday it will go in a case again lol)
Old 10-01-2009
HAPPY BIRTHDAY NEUROMANCER!!!!!!!!!
Old 10-01-2009
Cecil Cecil is offline
Cecil is just getting started
This might help you out a bit,
http://forums.extremeoverclocking.co...d.php?t=324998
Old 10-01-2009
Rogue210's Avatar
Rogue210 Rogue210 is offline
beyond a noob
happy b-day neuromancer
