Overclockaholics Forums » Overclocking Section » Extreme Overclocking » X58 has me baffled.. please help.
Old 09-30-2009
Default X58 has me baffled.. please help.
I sit at work right now thinking over what I have tried and it is truly astonishing as to the level at which i have gone to achieve stability with little success.
I can run 20x 200 with HT without turbo.... if i enable turbo it will not pass testing or will bsod on boot.
i can run turbo at 191x19 and get a lil over 4.0 ghz...
to run 200x20 i need vcore at 1.36 vtt/qpi at 1.412 just to run stable
can only run ram at 1600 mhz, and uncore at 3200 any higher and she has a fit.
if i set the ram at the default 2000 mhz even at looser timings it wont boot.
as soon as i get home i will post bios template... just trying to get ideas here
same issue with 2 cpu's btw so that tells me that its probably me making the error.
